    GPIO Y axes don't work on player 1
    GamePad/GPIO/USB encoder
    gpio axes dont player
    • Nokiandrea
      Nokiandrea last edited by
      Hi, I enabled gpio controller from recalbox.conf but I had a problem.
      All pins works fine, doesn't work Y axes pin for player 1.
      Anyone have same problem? Can you help me? Thx 🙂
        Substring @Nokiandrea last edited by
        @Nokiandrea maybe you missed the wiring ? Have you tested with evtest ? Are you sure you don't hav a sort circuit somewhere ? Or a dead switch ? Or a dead gpio pin ?
        • Nokiandrea
          I checked all connections with a tester. I run jstest and connect a wire in a gnd pin and the other end at all pin for check. Works all, don't work UP (pin 7) and Down (pin 11) for Player 1 😞
          Can i customize gpio pin ?
            @Nokiandrea as for now you can't. This may be possible on 4.1, someone submitted some code to do so. Anyway, you'd need 2 pins, there's nothing left free
            101.4k
