    share partition problem...
    4425
    • reigel
      reigel last edited by
      Well, not really a problem but..
      I wanted to ask where can I find how /dev/mmcblk0p7 was mounted on /recalbox/share folder.
      I tried looking at /etc/fstab following instructions from Auto mount of usb in place of share partition (EN) but it wasn't there. I'm trying to get this to work, but something is wrong in that instructions. Starting this line: Add a # to comment the line :
      It wanted to add a # on the output of mount command?
      Anyway, I know how fstab works, and I could easily edit that to add my usb stick. But I'm curious how /dev/mmcblk0p7 was mounted on /recalbox/share. It's not in the fstab. Might be better to do the same and not mess with fstab.
      Anyone got any idea? I'm not really a linux guy... I just know some basic stuff.
      Thanks
      P.S.
      I don't want to use the "Press Start > System Settings". Because I disabled that menu for a reason that when I tried to get inside it, all I see is black screen with recalbox logo. I'm now using a bartop menu.
        Substring @reigel last edited by
        @reigel the mounting is handled by some init scripts, not fstab + some infos in /boot
        What are you trying to achieve ?
        PreferLurking 1 Reply Last reply Reply Quote 0
        • mchack23
          mchack23 last edited by
          if I might "hijack" this thread I have a very similar problem: (guess you want usb, I want nas in the end it's the same, we want to manually define which device should be mounted on /recalbox/share)
          Want:
          mount nfs share as /recalbox/share to have my roms on network attached storage where they should be. (imho 😉
          works manually:
          entry into fstab:
          ip:path-to/recalbox-share /recalbox/share nfs4 rsize=32768,wsize=32768,timeo=14,intr,tcp 0 0
          and then umounting the sdcard partition and mounting /recalbox/share and then restarting the emulationstation.
          works ok with custom.sh:
          mount /recalbox/share/
          /etc/init.d/S*emulationstation restart
          but both make booting quite long and "not nice"
          I'd rather have an option to enable the fstab entry from /etc/init/S11share or the relevant conf file in /boot where you can specify ANYEXTERNAL or INTERNAL or a UUID but alas not an nfs share or telling it to use the fstab.
          so I'm a bit at a loss at how to configure it to work nicely 😉 hope someone has a suggestion, thanks.
            Substring @mchack23 last edited by
            @mchack23 that's for 4.1. Meanwhile, read the wiki to know how to mound a NAS
            • PreferLurking
              PreferLurking @Substring last edited by
              @Substring
              I want to convert the share partition filesystem from ext4 to hfsplus.
              I have converted to vfat for now, but I want to allow for files larger than 4GB, while still being able to edit recalbox.conf from a jailbroken ipad.
              I inserted an hfsplus usb drive and it did not automount, but I was able to mount it manually from the command line via ssh, so the support is built in already. If I just re-format the partition to hfsplus, will it automount?
              Which script controls mounting this partition?
              Thanks
                what do you mean "did not automount" ? where di you expect it to be mounted ?
