    how to use GPIO ??
    GamePad/GPIO/USB encoder
    gpio
    • jingu
      jingu last edited by
      how to use GPIO ??
      1. install recalboxOS-4.0.0-beta5.zip
      2. boot
      3. putty connect my raspberry pi
      4. login as : root // root@192.168.1.31's password: recalboxroot (enter)
      5. <- show my display
      6. type (https://github.com/recalbox/mk_arcade_joystick_rpi)
        mkdir mkjoystick
        cd mkjoystick
        wget https://github.com/digitalLumberjack/mk_arcade_joystick_rpi/releases/download/v0.1.4/install.sh
      7. type
        sudo sh ./install.sh updatesystem
      8. show error
        -sh: sudo: command not found
      How should the problem be solved
        voljega Banned @jingu last edited by voljega
        @jingu Read the manual and the wiki. Also the rules of the forum before posting.
        • MikaXII
          MikaXII Staff last edited by
          https://github.com/recalbox/recalbox-os/wiki/GPIO-controllers-(EN)
          mika@recalbox.com
          101.4k
