    Transferring Roms with Macintosh (Cyberduck)
    macintosh recalbox 4 filezilla
    • Everett999
      Everett999 last edited by
      Hi,
      While the browser methods works well with small files, the video said anything over 100MB doesn't work. Is that correct or has this been corrected in 4.00 beta 5?
      I used Cyberduck (an FTP program like Filezilla) to transfer roms to Retro Pie but i can seem to get it to work on Recalbox.
      1. Do I use FTP or SFTP (SFTP on Retro Pie port 22)?
      2. What is login and password? In Retro pie it is PI and raspberry.
      Any other setting?
      Thanks
        Hey !
        You don't even need to use sftp, just browse your network to connect like to any windows network share
        If you do.insist on cyberduck, then use sftp with credentials root/recalboxroot
        Everett999 1 Reply Last reply Reply Quote 0
        • Everett999
          Everett999 @Substring last edited by
          @subs thanks that works!
