    Wifi Captive Portal Login
    wifi captive portal login
    • goldenpansy
      goldenpansy last edited by
      Hello there.
      I am planning to use my recalbox on a Pi3 at my college dorm... but the wifi connection there has a captive portal in which I have to login in order to connect to the internet. Usually this is one through a web browser... but since Recalbox doesn't feature any (nor it does have a virtual keyboard) I was wondering if there's a way to setup a script to login automatically at the startup of Recalbox-OS.
      Any help is appreciated!
        Mmmmhhhhh check the from of you webpage, i think you could use curl to post the expected vars if they are not encrypted
