    MK Arcade Driver Questions
    GamePad/GPIO/USB encoder
    arcade driver
    • nokele
      nokele last edited by nokele
      Hiho
      @digitaLumberjack
      I have a question about your MK-Arcade Driver.
      I am building a Handheld an put my Buttons directly to the GPIO. I'll use your MK-Arcade Driver but there is one Problem.
      It seems that your Driver doesn't support more then 8 Buttons. I know that's because your driver supports a second player. But in my case I don't need second player support. Is there a way to use the second player pins for more than 8 buttons?
      Have a nice Day 😊
        Hi
        For now, the driver can only map 9 buttons (x b y a l r start select and hotkey). You'd need to edit the driver to add more buttons for a single player
