    Moonlight - Rayman cant play more than 2 players.
    Emulator Arcade/PC/Console
    rayman cant play more players
    • sirus555
      sirus555 last edited by acris
      Hi
      I have had this issue with other builds including my on custom one where despite I have two registerd controllers, I can not play multiplayer. I am streaming Rayman Origins and Legends via moonlight players 1 is fine, players 2 doesnt work, but looking in rayman control settings, the buttons are mapped as I would expect. Playing directly on pc works fine.
      Has any had this issue or similar and managed to fix it?
      edit modo : modified title
        your title should at least mention that this is a moonlight problem ...
        recalbox maps all (up to) 4 controllers for moonlight. I've been playing Ultra Street Fighter IV with my arcade stick plugged on recalbox, both players were working. Might be a game/streaming specific problem.
        Could you try while unplugging the pad on your pc ?
        • sirus555
          The controls are plugged into moonlight. Unplugging them just make the xbox button l.e.d. flash
          Running the game directly from PC with controls plugged into PC works fine.
          I guess this a moonlight issue then?
            Unplug any controller from your pc !
            And no, this is no moonlight issue but a nvidia one
