    Having To Re-Configure Arcade Joystick Periodically
    having re-configure arcade joystick periodically
    3689
    • tdelios
      tdelios last edited by
      I'm using the Raspberry Pi 2 and 3 with a Xin-Mo and arcade (zippy) joystick and arcade buttons.
      one problem I noticed periodically, and even with the latest and previous versions of Recalbox is that periodically my joystick doesn't work. Its annoying that I have to locate my USB keyboard, plug it into my Raspberry Pi so that I can traverse through the Emulation Station menu to get to the controller setup and re-configure the joystick again before I unplug and store away the keyboard.
      Not sure what is causing it, but happens frequently enough that I keep the usb keyboard nearby.
      side note - I also noticed this problem when I use my playstation controllers from time to time as well.
      Can anybody advise what I may need to tweak or change to ensure joystick configuration is maintained.
        there are no reasons you should reconfigure except if :
        • your es_input.cfg gets broken
        • your buttons change bus or events number
        If your pi is on the network, you can use the virtual gamepad to browse through the menus instead of plugging your keyboard
        tdelios 1 Reply Last reply Reply Quote 0
        • tdelios
          tdelios @Substring last edited by
          @subs my pi is on the network. How can I use the virtual gamepad to browse through the menus instead of plugging in my keyboard?
            find your pi IP address, then http://IP:8080
            On a windows pc you can just http://recalbox:8080 or http://recalbox.local:8080 for linux and mac
            • tdelios
              @subs so I see the virtual keypad. So how does that help me again to re-configure the joystick without the use of a usb keyboard?
              second question. How does my es_input.cfg file get broken and which folder is it located (via Windows networking to the Recalbox) so that I can see what it looks like when the problem comes up again
                the virtual gamepad just helps not to plug a keybooard to reconfigure, that's all
                es_input.cfg is located in ~/.emulationstation on the SD, or \\recalbox\share\system\.emulationstation through windows network shares
