    Can't pair bluetooth controller
    GamePad/GPIO/USB encoder
    cant pair bluetooth
    5965
    • cyborgjeff
      cyborgjeff last edited by
      Hello the community !
      So, i've installed recalbox few month ago. I've two bluetooth controller but i can't pair it. It's an SFC30 and NES30 from 8bitsdo. Those one works fine with the USB cable, but i can't use it in bluetooth wireless mode.
      In fact, asap i push the button inside the controller menu of Recalbox, i had a message on the screen "no controller found" I don't have any searching box or just searching time... directly no controller found.
      So, i can't pair the device for instance in my smartphone.
      How to check what's wrong... for instance if Recalbox manage well the bluetooth of my Raspberry 3 model B ?
        I think you expected the pi3 internal bt to work ? Wait for 4.1
        • cyborgjeff
          That means this internal Bluetooth was for now not supported by Recalbox ?
            Indeed. Long story short : the pi3 bt works with a minimum system bt stack version tjat we didn't (and couldn't) meet at the moment. And the switch was painful ...
            cyborgjeff 1 Reply Last reply Reply Quote 0
            • cyborgjeff
              cyborgjeff @Substring last edited by
              @subs Arf... and what about 4.1 recalbox release ?
              The one who also support C64 as i remember... =[
                The first unstable should hit tge sgelves shortly after the stable 4.0.0
                • Dinierto
                  Dinierto Banned last edited by
                  I'm glad I found this thread. I was thinking of buying a Bluetooth dongle but if built in support is being added I will wait.
                  101.0k
