    Xbox 360 Mad Catz WWE All Stars Brawl Pad
    GamePad/GPIO/USB encoder
    xbox 360 mad catz wwe
    • MrEscience3000
      MrEscience3000 last edited by
      If anyone can help, I would be very thankful. I just picked this(https://www.amazon.com/Xbox-360-WWE-All-Stars-Brawl/dp/B004M22C0S) up dirt cheap and was hoping to use it with my rasp pi 3; I am currently running the latest version of Recalbox. Does anyone know if I am able to map the LT and RT on this controller, they are in the b*mper position on this controller design. They don't register when I configure the controller, but if I hold them down they will skip an input. Everything else works fine on the config, I can even setup the right and left analog sticks with the button on the back of the controller. Am I doing something wrong?
      Here is the link to the controler if needed:
      Thanks for any help in advance.
        Would be great if you could send the output file of /recalbox/scripts/recalbox-supoport.sh and upload it somewhere 🙂
        You may also SSH to your recalbox, run evtest, and check that both your buttons work and mention if they are like AXIS, BTN or KEY. If you can't, don't worry, i'll get that in the file you will upload.
        • MrEscience3000
          I will try once I get a chance to; it may be later this week though. Thank you for your response. I did make a mistake in my previous post; the LT and RT buttons DO NOT respond in the config menu. Again thanks for the help I will send the output file of /recalbox/scripts/recalbox-supoport.sh and upload it once I can. I'm still new to this whole thing so any patience is appreciated. Thanks!
