    Solved [snes] not possible to play games like kirbys dreamland 3
    Emulator Arcade/PC/Console
    [snes] possible play kirbys dreamland
    • dwx
      dwx last edited by
      or smw 2 - yoshis island cause it yells about using a mouse or other controllers than the pad. how to solve? (i am not using any other peripherals than my F710 controller)
      recalboxOS 4.0.0-beta4 | RPI3
        hi
        you just need to change the core for those games that don't like the multitap. Once on your rom, press select, edit metadata, change the emulator to libretro and try another core instead of snes9x.
        You could have searched a little before posting your question 😉 there are many topics like yours !
        dwx 1 Reply Last reply Reply Quote 1
        • dwx
          dwx @Substring last edited by
          @subs okay, but thanks anyway 🙂
