    How to remove battery indicator display ?
    Themes & Interface
    recalbox 9 display battery screen
    • dalbors
      dalbors last edited by
      Hi everyone,
      An icon representing battery power level is always present on the right upper corner of my screen.
      Does anybody knows how to remove it ?
      Dorispeland 1 Reply Last reply Reply Quote 1
      • Asalam
        Asalam last edited by Asalam
        Hi!
        It sounds like your system is displaying a battery indicator overlay. To remove it, try the following based on your setup:
        1. If Using EmuELEC or Batocera:
          Go to Main Menu > UI Settings and look for an option related to battery display.
          Some themes have battery indicators enabled by default—switching to a different theme may remove it.
        2. If Using RetroPie on a Handheld Device:
          If you have a script generating the overlay, check your /opt/retropie/configs/all/autostart.sh file for any battery-related commands.
          You can disable any script running cat /sys/class/power_supply/BAT0/capacity or similar.
        3. If Using a Custom Theme in EmulationStation:
          Some themes hardcode battery icons. Try switching to a different theme under UI Settings > Theme.
          If the icon is part of the theme, you may need to edit the theme’s XML files (located in /etc/emulationstation/themes/your_theme).
          Let me know what system you're using, and I can give more specific steps! 😊
        • Dorispeland
          Dorispeland @dalbors last edited by
          You can usually hide it in the system settings! Check your “Display” or “Status Bar” options — there should be a toggle to turn the battery icon off. What device or OS are you using?
          4o
