    About Configuring Recalbox for Dual Boot Setup
    configuring recalbox dual boot setup
    • laban48707
      laban48707 last edited by Pitch64
      Hey guys......
      I am new to using Recalbox and have been loving the experience so far! I am currently looking into setting up a dual boot system on my Raspberry Pi 4, with Recalbox as one of the OS options.
      I have done some basic research but wanted to ask here for advice from the community:
      • Is there a preferred method or tool for creating a dual boot setup with Recalbox?
      • Are there any specific configurations or precautions I should take to ensure Recalbox runs smoothly in this setup?
      • Has anyone experienced performance issues or limitations with dual booting, particularly when switching back and forth between systems?
      I also check this: https://forum.recalbox.com/topic/27730/recalbox-electron-8-1-1-emulation-station-main-me But I have not found any solution. Could anyone guide me about this? I am open to any tips or recommendations, especially from those who have done this themselves.
      Thanks in advance for your help!
      Respected community member!😊
      • cm4_RF_user
        cm4_RF_user last edited by
        you won't get this to dual boot. I would say mission impossible!
        recalbox is basically an embedded system and an emulator. if you look at the way config.txt boots the OS you will see there is no extra way of handing off the firmware to booting the kernel when kms takes over. You would have to take over and boot a NON embedded kernel at firmware handoff time.
