    Solved [SOLVED] Gampepad lag
    GamePad/GPIO/USB encoder
    gampepad lag
    7495
    • izno
      izno last edited by izno
      Simple problem, i have a delay of 20-40 ms on my gamepad. Its a cheap SNES look a like.
      This is a big issue when playing SuperMario etc as you constantly miss jumps. Anyone have / had a simulere issue?
      • supernature2k
        supernature2k last edited by
        What you can do:
        -check your TV, put game mode, de-activate any image enhancement.
        -In retroarch, de-activate threaded video, Hard GPU sync ON and Hard GPU sync frames: 5
        Scandy 1 Reply Last reply Reply Quote 1
        • izno
          Thank you, i feel like an idiot. It was the tv 😉
          (If this was a playstation this would never happen, you dont think of this as a game system like that haha).
          If the developers is reading this forum i would like to show my appreciation! Well done!
          • supernature2k
            Glad it was helpful.
            Don't forget to upvote messages if it has been useful 😉
            The developpers will certainely read this, thx for them!
            • Scandy
              Scandy @supernature2k last edited by
              @supernature2k said in [SOLVED] Gampepad lag:
              What you can do:
              Hi,
              just curious: how "Hard GPU sync" and "frames" options help reducing input lag?
              Thank you!
              • supernature2k
                It helps gain a few ms
                • MarcDK
                  MarcDK last edited by
                  I tried to access retro arch in 4.1 beta but there are no core options. Where can I set this configuration?
                  https://marc.tv
                    Substring @MarcDK last edited by
                    @marcdk don't necro 1 year old topics dude !
