    RaspPi 5b - frozen splash screen after shutdown
    rasppi frozen splash
    • cjhudson101
      cjhudson101 last edited by cjhudson101
      Hello all,
      I searched around for this specific issue, but haven't seen a post that quite matches.
      I have the latest recalbox 9.2.3-pulstar installed on a Raspberry Pi 5b 4gb (via pi imager onto an SD card). Things all seem to be working great until I shut down the unit. I go to the system menu and choose shutdown. Shutdown appears to work properly. At this point I turn off the power to my screen and RaspPi via a power strip.
      The next time I turn on my Pi I hang at the splash screen. I can SSH into my Pi and if I enter the "reboot" terminal command the Pi reboots. Upon reboot my recalbox starts up normally and things are fine. Unfortunately I do not want to leave my Pi on 24x7 and this is a minor inconvenience.
      What should I be looking for as to why a process hangs or fails to start automatically on boot up after a successful shutdown?
      Thanks!
      --Chris
      • Stewart 0
        Stewart 0 last edited by
        It sounds like your Raspberry Pi might not be completing the shutdown process correctly, possibly due to a service hanging or an issue with the SD card. You could try checking the system logs using journalctl -b -1 to see if any errors appear from the previous shutdown. Also, a fresh install on a different SD card might help rule out corruption issues. On a side note, if you're into creative projects, you might find https://alight-motion-apk.com/ useful for video editing and animations. It offers professional-grade tools for creating stunning motion graphics right from your mobile device!
