    Solved Help with Romcenter software
    romcenter rom roms file manager no-intro
    4078
    • 8bit_astronaut
      8bit_astronaut last edited by
      Hello everyone, i had this kind of question, well, my problem is, i downloaded one of those no-intro romsets, and i wanted to had only 1 rom per game (1g1r) but i dont know how to make it!!!
      Some people recommended me romcenter and romulus, but the problem is, i dont have idea of how to use it.
      I searched tutorials, but all the tutorials are for mame games, not for no-intro or goodtools romsets.
      Please, any help here?
        @Nachtgarm i'm sure you're a romce ter guru and you can answer him 🙂
        • supernature2k
          supernature2k last edited by
          There are tutos on various site.
          Mame and fba work the same way, just give a fba .dat (available here on the wiki) to romcenter instead of a mame .dat.
          • Nachtgarm
            Nachtgarm @8bit_astronaut last edited by
            @8bit_astronaut
            You can't edit DAT files with ROMulus, nor with ROMcenter. Not in a comfortable way. You need to use datutil (Commandline/Win) by Loqix, or DATWorkshop Pro (GUI/Win) by emulab to edit a DAT File automatically.
            What whould help as well is the Unviersal Rom Cleaner by Screech
            • 8bit_astronaut
              I had to say, universalromcleaner is perfect!
              The most easy, simple, and nicelooking program for winddows that i ever find.
              Thank you so much @Nachtgarm
              • 8bit_astronaut
                The only problem that i had is this, i dont understand French, so i cant understand the tutorial in the github page ;_;
                • supernature2k
                  Ah you were talking about consoles roms! how dumb I am...
                  If the soft helped you, thanks its author who does a wonderful job (check also Universal XML Scraper).
                  Here is the official post:
                  https://forum.recalbox.com/topic/2344/soft-universal-rom-cleaner-nettoyez-vos-romset-d-une-main-clean-your-romset-with-one-hand
