    Impossible to configure buttons/joysticks
    GamePad/GPIO/USB encoder
    configure
    • jonzuzu
      jonzuzu last edited by
      Hello all,
      Recalbox 9.2.3 and Rapsberry Pi4.
      Using 2 USB encoder zero delay from the configuration menu i am not able to configure the joystick and buttons.
      Each buttons and joystick direction are detected because the pad icon on the top left is lighted on, but pressing on button to set it does not have any actions.
      Using the sdl-jstest --list command returns there are 2 DragonRise Inc. Generic USB Joystick.
      With the sdl-jstest --test command, all the buttons and joystick directions are well detected.
      Do you have any ideas ?
      • jonzuzu
        No idea how to debug my issue ?
        Do you need more information ?
        • Magaki
          Magaki last edited by
          Hello, not owning arcade stuff for help.
          There's more activity on Discord for support 🙂
