    No sound after update to v9.2.3
    sound update v9.2.3
    • hanjo
      hanjo last edited by
      Hi,
      in the past, whenever I updated I had to execute the steps listed in the Wiki to get the sound to work.
      I'm running Recalbox on a Raspberry Pi 4, which is connected with HDMI to a Yamaha AV receiver.
      I updated from v9.1.something to v9.2.3 yesterday, but the step described in the Wiki does not fix the issue any more. I'm suspect this is somehow similar to the issue described here, but I could not see a solution.
      Any suggestions?
      Thanks
      Hanjo
      • hanjo
        After some debugging, I finally figured it out. The steps in the Wiki are still correct. However the update to v9.2.3 somehow screwed up the audio settings within the Recalbox UI and used the analog output as default again. Manually changing it to HDMI fixed the issue.
        rciocheta 1 Reply Last reply Reply Quote 0
        • rciocheta
          rciocheta @hanjo last edited by
          @hanjo Hi friend! I have the same issue. How did you fix it? Where did you change the sound settings? Thanks
          RPi 3B/NesPi case /sd 64Gb/Recalbox 2018.07.13
          RPi 3B+/MegaPi case/sd 128Gb/Recabox Beta 2019.02.23
          02 DualShock 3 + 8Bitdo SN 30
          • rciocheta
            rciocheta last edited by
            Ok. Its in Recalbox UI. I found it. Thanks.
