    Recalbox 9.2.2 show wrong resolution using (hdmi_mode=87)
    recalbox 9.2.2 show wrong hdmimode87
    • porronca
      porronca last edited by
      Board model: Raspberry Pi 3b
      Recalbox version (build): 9.2.2 - Pulsar
      Hardware:
      • Sandisk 256GB SD card
      • 5v 3a power supply
      • Retroflag Megapi case
      • Sony Wega CRT-TV (KV-29FS110) over component through this transcoder
      I'll try to keep it brief:
      I had a perfectly running system with a VGA666 board and a VGA to YPbPr transcoder.
      Then, I decided to buy a Retroflag MegaPi case to make everything look nicer.
      Unfortunately, it's not possible to use the VGA666 with this Retroflag case.
      To solve this, I bought an HDMI to YPbPr transcoder that doesn't upscale the image at all the resolution and frequency that go in are the same as what comes out.
      I followed the tutorial from Recalbox Wiki.
      This setup worked fine on Recalbox 7.2.2.
      • Emulation station in 480i
      • Games in 240p
      However, after Recalbox 9.2.2 fresh install, it seems recalbox.conf doesn't accept the global.videomode=DMT 87 HDMI command for the (1920x240 @ 60Hz) resolution (hdmi_cvt=1920 240 60 1 1 0 0) specified in recalbox-user-config.txt.
      Instead, the system displays at (1280x720 @ 60Hz) - verified on a modern LCD TV -.
      During boot, my monitor shows 480i, then switches to 1280x720 just before launching Emulation Station.
      My goal is to archieve the same results as i got in Recalbox 7.2.2
      Here are my recalbox-user-config.txt settings:
      # Change to your needs
      hdmi_pixel_encoding=2
      # uncomment if you get no picture on HDMI for a default "safe" mode
      #hdmi_safe=1
      disable_overscan=0
      overscan_scale=1
      # uncomment to adjust overscan
      overscan_left=22
      overscan_right=34
      #overscan_top=16
      #overscan_bottom=16
      # uncomment to force a specific HDMI mode
      hdmi_group=2
      hdmi_mode=87
      # Sound output. Set to 0 or comment for autodetect, 1 for DVI, 2 for HDMI.
      hdmi_drive=2
      config_hdmi_boost=0
      # uncomment for composite PAL
      #sdtv_mode=2
      # uncomment for lirc-rpi
      #dtoverlay=lirc-rpi
      # uncomment if display is garbled or slow
      hdmi_ignore_edid=0xa5000080
      In recalbox.conf, I only changed:
      system.es.videomode=CEA 6 HDMI
      With the VGA666 board and transcoder, the setup was straightforward and effective. So, it would be great to have an option to switch to CRT mode "DMT 87 HDMI - 1920x240@60" (or something like that) directly through the menu system using Advanced configuration => Recalbox CRT, just like Recalbox RGB DUAL, VGA666, etc options in that menu... which are not suitable with many raspberry cases.
      While this is a feature suggestion, I would be happy to resolve this problem by editing the configuration files.
      Congrats for all team on the excellent work!
