    Generic USB Controller
    GamePad/GPIO/USB encoder
    generic usb
    4200
    • cerealfordinner
      cerealfordinner last edited by
      I was wondering if there is a way to configure a generic usb controller to be used with Recalbox. Im currently using a Logitech F310 and it works perfectly but i ordered some generic usb snes controllers off of Amazon and i haven't been able to get them to work. I know they're not listed on the compatibility page, but i was hoping there was something else i could do to get them to work.
        Plug your pad as well as your f310, go to controller settings, try to configure your new pad
        • cerealfordinner
          @subs I tried that both with the Logitech controller and with the keyboard and it just doesnt see the controller. I even put the listed configs from the Github repo into the udev folder and still nothing.
            Keep everything plugged, run /recalbox/scripts/recalbox-support.sh, send the generated file, i'll have a look
            • cerealfordinner
              @subs once i ssh into the Pi and change to that directory how do i go about running that script?
              • cerealfordinner
                @subs
                sh recalbox-support.sh
                evtest: No such file or directory
                device node not found
                /recalbox/share/saves/recalbox-support-20160730030335.tar.gz
                  You should upload somewhere on the web that file
