    Amiga 1200 says Missing bios for amiberry
    GamePad/GPIO/USB encoder
    help bios amiga
    • mark25810
      mark25810 last edited by
      Hi there i installed recalbox
      I loaded 4 amiga games and they are listed in the 120p
      When i click a game it says
      Atleast one mandatory bios is missing for amiberry
      And wont run untill its required bios is out in the correct folder
      I installed all the Kickstarter files in the bios folder and named them correctly
        Scavy Global moderator @mark25810 last edited by
        @mark25810
        Hello, check that the name of the bios is correct and respects upper and lower case letters. Also check that the bios are validated in the recalbox bios tab.
        I closed the same topic opened here :
        https://forum.recalbox.com/topic/34388/help-with-amiga-1200-and-bios-issue
