    problem with recalbox theme "Theme Next Pixel"
    Themes & Interface
    recalbox theme theme next pixel
    • jose89fcb
      jose89fcb last edited by
      Hello, very good, I am having some small problems with the topic:
      https://forum.recalbox.com/topic/16064/recalbox-9-theme-next-pixel
      Here I show some images
      the texts are cut between
      alt text
      In this other image of the same topic an overlay appears
      alt text
      I'm using a raspberry pi 5 with Recalbox 9.2-experimental
      Any solution? thank you so much!
      • Magaki
        Magaki last edited by
        Hello,
        You are using a theme for 9.0 on a 9.2, it could be normal to see some defects like that if the theme is not compatible with latest version.
        Also, it's better to comment directly on theme topic, rather than a new topic : https://forum.recalbox.com/topic/16064/recalbox-9-theme-next-pixel
