    HDMI screen changer with raspberry PI5
    hdmi raspeberry pi5
    • St3ffy
      St3ffy last edited by St3ffy
      Hello everyone,
      I was using with a raspberry pi 4 an HDMI hub because there was only one HDMI output ( Screen of my emulation terminal and screen of my TV)
      I switched to raspberry PI 5 which has 2 HDMI outputs, recalbox doesn't seem to recognize the 2nd HDMI port.
      Is this because it hasn't been implemented yet, or is there a parameter to activate?
      Ideally, I'd like to stop using an HDMI HUB on one of the outputs, and use the menu to choose which HDMI port on the PI5 to send the image to
      • Lauryn
        Lauryn Banned last edited by
        It's possible that the second HDMI port on your Raspberry Pi 5 isn't recognized by recalbox due to a lack of implementation or activation parameters. Since you'd prefer to avoid using an HDMI hub and instead select which HDMI port to use through the menu, you might want to check for any updates or patches that enable this feature. Alternatively, you could explore configuration options within recalbox or the Raspberry Pi settings to see if there's a way to activate the second HDMI port manually.
