    Fresh 9.2-patron-4.1 not booting with GeForce GT 1030
    fresh 9.2-patron-4.1 booting geforce 1030
    • jeekajoo
      jeekajoo last edited by
      Hello 🙂
      I was using Patreon 9.2 successfully with integrated chipset on a i7-3770 CPU.
      Then I decided to buy a GeForce GT 1030 to have better performance.
      (I tested since graphic card successfully on a dedicated OS (Linux))
      ISSUE : Patreon does not boot with this graphic card. I have the first animation video but then ES does not start.
      Of course, I tried with a fresh install on a USB stick. Here is the support archive with this test
      https://fichiers.ouvaton.coop/f.php?h=1OECF6Ct
      Here is an extract from "recalbox.log" with a grep on "nvidia"
       ~/Downloads/recalbox/support/recalbox-support-20240413220613/system/logs $ grep nvidia recalbox.log
      [        2.67] [nvidia-install] [INFO] No Nvidia controller found, exiting...
      [        2.73] [nvidia-install] [INFO] No Nvidia controller found, exiting...
      [        3.25] [nvidia-install] [INFO] No Nvidia controller found, exiting...
      [        3.31] [nvidia-install] [INFO] No Nvidia controller found, exiting...
      [        3.08] [nvidia-install] [INFO] No Nvidia controller found, exiting...
      [        3.14] [nvidia-install] [INFO] No Nvidia controller found, exiting...
      [        3.56] [nvidia-install] [INFO] No Nvidia controller found, exiting...
      [        3.63] [nvidia-install] [INFO] No Nvidia controller found, exiting...
      [        3.27] [nvidia-install] [INFO] No Nvidia controller found, exiting...
      [        3.33] [nvidia-install] [INFO] No Nvidia controller found, exiting...
      [        3.29] [nvidia-install] [INFO] No Nvidia controller found, exiting...
      [        3.35] [nvidia-install] [INFO] No Nvidia controller found, exiting...
      [        3.18] [nvidia-install] [INFO] No Nvidia controller found, exiting...
      [        3.24] [nvidia-install] [INFO] No Nvidia controller found, exiting...
      [        3.19] [nvidia-install] [INFO] No Nvidia controller found, exiting...
      [        3.15] [nvidia-install] [INFO] No Nvidia controller found, exiting...
      [        3.22] [nvidia-install] [INFO] No Nvidia controller found, exiting...
      [        3.12] [nvidia-install] [INFO] No Nvidia controller found, exiting...
      [        3.20] [nvidia-install] [INFO] No Nvidia controller found, exiting...
      [        3.30] [nvidia-install] [INFO] No Nvidia controller found, exiting...
      [        6.54] [nvidia-install] [INFO] No Nvidia controller found, exiting...
      [        6.60] [nvidia-install] [INFO] No Nvidia controller found, exiting...
      [        2.61] [nvidia-install] [INFO] No Nvidia controller found, exiting...
      [        2.79] [nvidia-install] [INFO] No Nvidia controller found, exiting...
      [        2.60] [nvidia-install] [INFO] No Nvidia controller found, exiting...
      [        2.66] [nvidia-install] [INFO] No Nvidia controller found, exiting...
      [        2.85] [nvidia-install] [INFO] No Nvidia controller found, exiting...
      [        2.92] [nvidia-install] [INFO] No Nvidia controller found, exiting...
      [        2.89] [nvidia-install] [INFO] No Nvidia controller found, exiting...
      [        2.95] [nvidia-install] [INFO] No Nvidia controller found, exiting...
      [        2.71] [nvidia-install] [INFO] No Nvidia controller found, exiting...
      [        2.77] [nvidia-install] [INFO] No Nvidia controller found, exiting...
      [        2.70] [nvidia-install] [INFO] No Nvidia controller found, exiting...
      [        2.76] [nvidia-install] [INFO] No Nvidia controller found, exiting...
      [        3.05] [nvidia-install] [INFO] Trying to install Nvidia controller 10de:1d01
      [        3.06] [nvidia-install] [INFO] Product 0x1d01 is supported! Installing Nvidia proprietary driver version 535.54.03
      [        3.06] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/xorg/drivers/nvidia_drv.so to /usr/lib/xorg/modules/drivers/nvidia_drv.so
      [        3.06] [nvidia-install] [INFO] Link /lib/modules/6.1.32/extra/nvidia.ko.535.54.03 to /lib/modules/6.1.32/extra/nvidia.ko
      [        3.07] [nvidia-install] [INFO] Link /lib/modules/6.1.32/extra/nvidia-drm.ko.535.54.03 to /lib/modules/6.1.32/extra/nvidia-drm.ko
      [        3.07] [nvidia-install] [INFO] Link /lib/modules/6.1.32/extra/nvidia-modeset.ko.535.54.03 to /lib/modules/6.1.32/extra/nvidia-modeset.ko
      [        3.07] [nvidia-install] [INFO] Link /lib/modules/6.1.32/extra/nvidia-uvm.ko.535.54.03 to /lib/modules/6.1.32/extra/nvidia-uvm.ko
      [        3.07] [nvidia-install] [INFO] Link /usr/share/glvnd/egl_vendor.d/10_nvidia.json.535.54.03 to /usr/share/glvnd/egl_vendor.d/10_nvidia.json
      [        3.07] [nvidia-install] [INFO] Link /usr/share/glvnd/egl_vendor.d/10_nvidia_wayland.json.535.54.03 to /usr/share/glvnd/egl_vendor.d/10_nvidia_wayland.json
      [        3.07] [nvidia-install] [INFO] Link /usr/share/X11/xorg.conf.d/10-nvidia-drm.conf.535.54.03 to /usr/share/X11/xorg.conf.d/10-nvidia-drm.conf
      [        3.07] [nvidia-install] [INFO] Link /usr/bin/nvidia-settings.535.54.03 to /usr/bin/nvidia-settings
      [        3.07] [nvidia-install] [INFO] Link /usr/bin/nvidia-smi.535.54.03 to /usr/bin/nvidia-smi
      [        3.07] [nvidia-install] [INFO] Link /usr/bin/nvidia-xconfig.535.54.03 to /usr/bin/nvidia-xconfig
      [        3.07] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/xorg/extensions/libglxserver_nvidia.so.535.54.03 to /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so
      [        3.08] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/xorg/extensions/libglxserver_nvidia.so.535.54.03 to /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so.535.54.03
      [        3.08] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/xorg/extensions/libglxserver_nvidia.so.535.54.03 to /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so.0
      [        3.08] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/xorg/extensions/libglxserver_nvidia.so.535.54.03 to /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so.1
      [        3.08] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/xorg/extensions/libglxserver_nvidia.so.535.54.03 to /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so.2
      [        3.08] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libEGL.so.1.1.0 to /usr/lib/libEGL.so
      [        3.08] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libEGL.so.1.1.0 to /usr/lib/libEGL.so.1.1.0
      [        3.08] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libEGL.so.1.1.0 to /usr/lib/libEGL.so.0
      [        3.08] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libEGL.so.1.1.0 to /usr/lib/libEGL.so.2
      [        3.09] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libEGL_nvidia.so.535.54.03 to /usr/lib/libEGL_nvidia.so
      [        3.09] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libEGL_nvidia.so.535.54.03 to /usr/lib/libEGL_nvidia.so.535.54.03
      [        3.09] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libEGL_nvidia.so.535.54.03 to /usr/lib/libEGL_nvidia.so.0
      [        3.09] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libEGL_nvidia.so.535.54.03 to /usr/lib/libEGL_nvidia.so.1
      [        3.09] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libEGL_nvidia.so.535.54.03 to /usr/lib/libEGL_nvidia.so.2
      [        3.09] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libGL.so.1.7.0 to /usr/lib/libGL.so
      [        3.09] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libGL.so.1.7.0 to /usr/lib/libGL.so.1.7.0
      [        3.09] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libGL.so.1.7.0 to /usr/lib/libGL.so.0
      [        3.09] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libGL.so.1.7.0 to /usr/lib/libGL.so.2
      [        3.10] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libGLESv1_CM.so.1.2.0 to /usr/lib/libGLESv1_CM.so
      [        3.10] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libGLESv1_CM.so.1.2.0 to /usr/lib/libGLESv1_CM.so.1.2.0
      [        3.10] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libGLESv1_CM.so.1.2.0 to /usr/lib/libGLESv1_CM.so.0
      [        3.10] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libGLESv1_CM.so.1.2.0 to /usr/lib/libGLESv1_CM.so.2
      [        3.10] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libGLESv1_CM_nvidia.so.535.54.03 to /usr/lib/libGLESv1_CM_nvidia.so
      [        3.10] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libGLESv1_CM_nvidia.so.535.54.03 to /usr/lib/libGLESv1_CM_nvidia.so.535.54.03
      [        3.10] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libGLESv1_CM_nvidia.so.535.54.03 to /usr/lib/libGLESv1_CM_nvidia.so.0
      [        3.10] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libGLESv1_CM_nvidia.so.535.54.03 to /usr/lib/libGLESv1_CM_nvidia.so.1
      [        3.10] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libGLESv1_CM_nvidia.so.535.54.03 to /usr/lib/libGLESv1_CM_nvidia.so.2
      [        3.10] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libGLESv2.so.2.1.0 to /usr/lib/libGLESv2.so
      [        3.11] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libGLESv2.so.2.1.0 to /usr/lib/libGLESv2.so.2.1.0
      [        3.11] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libGLESv2.so.2.1.0 to /usr/lib/libGLESv2.so.0
      [        3.11] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libGLESv2.so.2.1.0 to /usr/lib/libGLESv2.so.1
      [        3.11] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libGLESv2_nvidia.so.535.54.03 to /usr/lib/libGLESv2_nvidia.so
      [        3.11] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libGLESv2_nvidia.so.535.54.03 to /usr/lib/libGLESv2_nvidia.so.535.54.03
      [        3.11] [nvidia-install] [ERROR] rmmod: ERROR: Module nouveau is in use
      [        3.11] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libGLESv2_nvidia.so.535.54.03 to /usr/lib/libGLESv2_nvidia.so.0
      [        3.11] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libGLESv2_nvidia.so.535.54.03 to /usr/lib/libGLESv2_nvidia.so.1
      [        3.11] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libGLESv2_nvidia.so.535.54.03 to /usr/lib/libGLESv2_nvidia.so.2
      [        3.12] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libGLX_nvidia.so.535.54.03 to /usr/lib/libGLX_nvidia.so
      [        3.12] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libGLX_nvidia.so.535.54.03 to /usr/lib/libGLX_nvidia.so.535.54.03
      [        3.12] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libGLX_nvidia.so.535.54.03 to /usr/lib/libGLX_nvidia.so.0
      [        3.12] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libGLX_nvidia.so.535.54.03 to /usr/lib/libGLX_nvidia.so.1
      [        3.12] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libGLX_nvidia.so.535.54.03 to /usr/lib/libGLX_nvidia.so.2
      [        3.12] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libvdpau_nvidia.so.535.54.03 to /usr/lib/libvdpau_nvidia.so
      [        3.12] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libvdpau_nvidia.so.535.54.03 to /usr/lib/libvdpau_nvidia.so.535.54.03
      [        3.12] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libvdpau_nvidia.so.535.54.03 to /usr/lib/libvdpau_nvidia.so.0
      [        3.12] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libvdpau_nvidia.so.535.54.03 to /usr/lib/libvdpau_nvidia.so.1
      [        3.12] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libvdpau_nvidia.so.535.54.03 to /usr/lib/libvdpau_nvidia.so.2
      [        3.13] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libGLX.so.0 to /usr/lib/libGLX.so
      [        3.13] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libGLX.so.0 to /usr/lib/libGLX.so.0
      [        3.13] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libGLX.so.0 to /usr/lib/libGLX.so.1
      [        3.13] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libGLX.so.0 to /usr/lib/libGLX.so.2
      [        3.13] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libGLdispatch.so.0 to /usr/lib/libGLdispatch.so
      [        3.13] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libGLdispatch.so.0 to /usr/lib/libGLdispatch.so.0
      [        3.13] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libGLdispatch.so.0 to /usr/lib/libGLdispatch.so.1
      [        3.13] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libGLdispatch.so.0 to /usr/lib/libGLdispatch.so.2
      [        3.14] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-eglcore.so.535.54.03 to /usr/lib/libnvidia-eglcore.so
      [        3.14] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-eglcore.so.535.54.03 to /usr/lib/libnvidia-eglcore.so.535.54.03
      [        3.14] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-eglcore.so.535.54.03 to /usr/lib/libnvidia-eglcore.so.0
      [        3.14] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-eglcore.so.535.54.03 to /usr/lib/libnvidia-eglcore.so.1
      [        3.14] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-eglcore.so.535.54.03 to /usr/lib/libnvidia-eglcore.so.2
      [        3.14] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-glcore.so.535.54.03 to /usr/lib/libnvidia-glcore.so
      [        3.14] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-glcore.so.535.54.03 to /usr/lib/libnvidia-glcore.so.535.54.03
      [        3.14] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-glcore.so.535.54.03 to /usr/lib/libnvidia-glcore.so.0
      [        3.14] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-glcore.so.535.54.03 to /usr/lib/libnvidia-glcore.so.1
      [        3.14] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-glcore.so.535.54.03 to /usr/lib/libnvidia-glcore.so.2
      [        3.15] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-glsi.so.535.54.03 to /usr/lib/libnvidia-glsi.so
      [        3.15] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-glsi.so.535.54.03 to /usr/lib/libnvidia-glsi.so.535.54.03
      [        3.15] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-glsi.so.535.54.03 to /usr/lib/libnvidia-glsi.so.0
      [        3.15] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-glsi.so.535.54.03 to /usr/lib/libnvidia-glsi.so.1
      [        3.15] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-glsi.so.535.54.03 to /usr/lib/libnvidia-glsi.so.2
      [        3.15] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-glvkspirv.so.535.54.03 to /usr/lib/libnvidia-glvkspirv.so
      [        3.15] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-glvkspirv.so.535.54.03 to /usr/lib/libnvidia-glvkspirv.so.535.54.03
      [        3.15] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-glvkspirv.so.535.54.03 to /usr/lib/libnvidia-glvkspirv.so.0
      [        3.15] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-glvkspirv.so.535.54.03 to /usr/lib/libnvidia-glvkspirv.so.1
      [        3.16] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-glvkspirv.so.535.54.03 to /usr/lib/libnvidia-glvkspirv.so.2
      [        3.16] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-tls.so.535.54.03 to /usr/lib/libnvidia-tls.so
      [        3.16] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-tls.so.535.54.03 to /usr/lib/libnvidia-tls.so.535.54.03
      [        3.16] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-tls.so.535.54.03 to /usr/lib/libnvidia-tls.so.0
      [        3.16] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-tls.so.535.54.03 to /usr/lib/libnvidia-tls.so.1
      [        3.16] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-tls.so.535.54.03 to /usr/lib/libnvidia-tls.so.2
      [        3.16] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-gtk2.so.535.54.03 to /usr/lib/libnvidia-gtk2.so
      [        3.16] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-gtk2.so.535.54.03 to /usr/lib/libnvidia-gtk2.so.535.54.03
      [        3.16] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-gtk2.so.535.54.03 to /usr/lib/libnvidia-gtk2.so.0
      [        3.16] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-gtk2.so.535.54.03 to /usr/lib/libnvidia-gtk2.so.1
      [        3.17] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-gtk2.so.535.54.03 to /usr/lib/libnvidia-gtk2.so.2
      [        3.17] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-gtk3.so.535.54.03 to /usr/lib/libnvidia-gtk3.so
      [        3.17] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-gtk3.so.535.54.03 to /usr/lib/libnvidia-gtk3.so.535.54.03
      [        3.17] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-gtk3.so.535.54.03 to /usr/lib/libnvidia-gtk3.so.0
      [        3.17] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-gtk3.so.535.54.03 to /usr/lib/libnvidia-gtk3.so.1
      [        3.17] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-gtk3.so.535.54.03 to /usr/lib/libnvidia-gtk3.so.2
      [        3.17] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-ngx.so.535.54.03 to /usr/lib/libnvidia-ngx.so
      [        3.17] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-ngx.so.535.54.03 to /usr/lib/libnvidia-ngx.so.535.54.03
      [        3.17] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-ngx.so.535.54.03 to /usr/lib/libnvidia-ngx.so.0
      [        3.18] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-ngx.so.535.54.03 to /usr/lib/libnvidia-ngx.so.1
      [        3.18] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-ngx.so.535.54.03 to /usr/lib/libnvidia-ngx.so.2
      [        3.18] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-ml.so.535.54.03 to /usr/lib/libnvidia-ml.so
      [        3.18] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-ml.so.535.54.03 to /usr/lib/libnvidia-ml.so.535.54.03
      [        3.18] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-ml.so.535.54.03 to /usr/lib/libnvidia-ml.so.0
      [        3.18] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-ml.so.535.54.03 to /usr/lib/libnvidia-ml.so.1
      [        3.18] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-ml.so.535.54.03 to /usr/lib/libnvidia-ml.so.2
      [        3.18] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-cfg.so.535.54.03 to /usr/lib/libnvidia-cfg.so
      [        3.18] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-cfg.so.535.54.03 to /usr/lib/libnvidia-cfg.so.535.54.03
      [        3.19] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-cfg.so.535.54.03 to /usr/lib/libnvidia-cfg.so.0
      [        3.19] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-cfg.so.535.54.03 to /usr/lib/libnvidia-cfg.so.1
      [        3.19] [nvidia-install] [INFO] Link /usr/lib/extra/nvidia-535.54.03/libnvidia-cfg.so.535.54.03 to /usr/lib/libnvidia-cfg.so.2
      [        8.80] [nvidia-install] [INFO] Populating /dev using udev: done
      [        8.80] [nvidia-install] [INFO] Boot vga card is /sys/class/drm/card0 from vendor 0x10de
      [        8.82] [nvidia-install] [INFO] Trying to install Nvidia controller 10de:0fb8
      [        8.83] [nvidia-install] [ERROR] GPU error(0x0fb8): Controller not supported. Is GPU?
      Thanks for any help
      Jeekajoo
      Patreon supporter since jan 2024.
      • jeekajoo
        And also, even if I force PCIE in the bios (over the iGPU), it doesn't work.
        bios picture
        For more context : The PC is connected with a direct HDMI cable on the TV (THOMSON 40FD3336 (HD TV 1080p)).
        Thanks
        • jeekajoo
          I figured out that the hard drive, on which I installed Recalbox (old install before new graphic card), was taking the lead over the fresh recalbox that I was trying to boot from (a usb key). I think the SHARE partition of the hard drive was auto-mounted and used instead of the SHARE partition of the USB key.
          It began to work when I disconnected the hard drive..
          Thank you to the folks on Discord that helped and motivated me to troubleshoot this.
