    hidden Wifi SSID
    hidden wifi ssid
    • soyde
      soyde last edited by
      I CANNOT CONNECT TO MY WIFI NETWORK WHEN SSID IS HIDDEN.
      I HAVE TESTED THIS BEHAVIOUR AT RECALBOX 3.3 AND THE LATEST 4 BETA, BUT BOTH OF THEM CANMOT CONNECT TO WIFI NETWORK WHEN WIFI SSID IS HIDDEN.
      ONCE YOU SHOW THE WIFI SSID, THE RPI CONNECT WITHOUT PROBLEM, BUT I WOULD LIKE TO HIDE MY SSID WIFI.
      HOW CAN WE FIX THIS BUG?
        Hey @soyde
        Hidden ssids are not handled unless you make some modifications yourself to some files ... I had the solution a long time ago which involved tweaning the wpa-supplicant.conf file as far as i remember
        Ps : mind pressing caps lock to use lower case ? 😉
        • soyde
          Thanks @subs, very interesting to know that is there any solution.
          Could you give me more information about modifications needed at wpa-supplicant.conf ?
          Thanks for your help.
            Look at https://www.raspberrypi.org/forums/viewtopic.php?f=28&t=25104 when the poster mentions scan_ssid=1
            BUT : i'm almost sure the conf file is generated at each boot, so you may have to edit /recalbox/scripts/reclbox-config.sh
            I can't check as I have no pi at hand until August. But i'm almost sure
            • Benoit bgl
              Benoit bgl last edited by
              hello, do you have found the config for connect to hidden ssid with recalbox?
