    Xbox wireless controller disconnects
    GamePad/GPIO/USB encoder
    xbox wireless disconnects
    • Basti1993
      Basti1993 last edited by
      Hi guys,
      I have the Xbox Wireless Adapter (6HN-00003) and could pair my Xbox Series X Controller.
      It works for 10 minutes and then the controller disconnects. The Wireless Adapter still shows a light but i need to reboot ES to make the controller connect again.
      (Also happens to an Xbox One Controller at the same time, so not a controller issue)
      In the log i see these entries when the issue occurs:
      [2024/01/24 21:53:20.166] (WARN!) : [/dev/input] Event 512 : /dev/input/event2
      [2024/01/24 21:53:20.224] (INFO ) : [InputManager] Initialize SDL Joystick system
      [2024/01/24 21:53:20.224] (INFO ) : [InputManager] Joystick count: 0
      [2024/01/24 21:53:20.244] (INFO ) : [InputManager] Refresh joysticks
      [2024/01/24 21:53:20.249] (WARN!) : [/dev/input] Event 512 : /dev/input/js0
      Can you help?
      Basti1993 1 Reply Last reply Reply Quote 0
      • Basti1993
        Basti1993 @Basti1993 last edited by
        @Basti1993
        Update:
        Also occurs on another Raspi4 with a vanilla Recalbox installation. So it is a general issue.
        When i use an older Xbox Wireless Adapter (the bigger one) it works for 30 min and then the controllers disconnect. I can reproduce that behaviour. The pairing button on the Wireless Adapter also doesnt work after that (LED is on but seems to be frozen). Only a reboot solves it. USB Cable works all the time.
