    USB availability at start
    Emulator Arcade/PC/Console
    usb availability start
    • carqueduc
      carqueduc last edited by
      Hi guy,
      I'm new in this forum, I hope RecalBox gives you as mush pleasure as it does to me.
      I've a issue with USB ports on my laptop when I launch RecalBox.
      I've installed RecalBox Pulsar 9.1 directly on disk, and it works fine.
      But when gamepad & wifi key are plugged before starting, Recalbox doesn't recognized them. I've to re plugged them when rb is running...
      Does this problem come from usb management by Recalbox?
      Do you have the same issue?
      Thanks
      Good game
      poppadum 1 Reply Last reply Reply Quote 0
      • poppadum
        poppadum @carqueduc last edited by
        @carqueduc I believe I have seen that before on other Linux systems. Does lsusb list the gamepad and wifi adapter when plugged in before powering on? I would also check the output of dmesg | grep usb to see if they are seen at all.
        I wonder if udevadm trigger would force a rescan of usb devices?
        There's also this neat idea which is to write a startup script to force the kernel to unbind then re-bind the driver from/to the relevant device IDs.
