    Moonlight.sh not found
    moonlight.sh
    3506
    • Anonpebbles
      Anonpebbles last edited by
      Hi I'm currently trying to get Moonlight to work and I think I've completely messed it up. I previously attempted to get it working on my Pi3 (4.0.0 beta 4) and Successfully got steam games to show up on recalbox. Unfortunately they would not work so I gave up on the idea for a while. I am now trying again using Setup Moonlight (EN) When I get to this step I get this message: # ./Moonlight.sh pair Moonlight Embedded 2.2.0 (EMBEDDED;CEC;PI) Too many options: No such file or directory Moonlight Embedded 2.2.0 (EMBEDDED;CEC;PI) Searching for Server... I believe I should just remove the contents of my Moonlight folder and replace them with a fresh install and then try installing moonlight again. I was wondering if someone could share a Moonlight folder which has not been messed with? Or any help with this issue would be greatly appreciated!
        I'd say your GFE is not advertising on your network ... if You want to delete anything related to a previous pairing, it's written in the wiki : "If you're stuck on pairing : delete /recalbox/share/system/configs/moonlight/keydir"
        • Anonpebbles
          Thank you I followed your advice and have been able to pair and get games to show up on Recalbox. However I cannot get the games to run. I was previously looking at a topic in which someone said you had a fix for this issue here. I was wondering if you could provide me with a link to this fix as I cannot seem to find it... Thank you so much for your help
            what controllers do you have ? There is a known bug with xbox pads The topic you found is not related to your problem, too old 😉
            • Anonpebbles
              I have a Logitech Wireless Gamepad F710. When I select a game the screen goes to a recalbox loading screen then fades back to the main menu. Hope this helps
                it doesn't help lol is the game launched on your PC ? can you log in SSH, type /etc/init.d/S31emulationstation restart, run a game and make a pastebin of the output ?
                • Anonpebbles
                  Just tried it! Here you go: http://pastebin.com/KFY494sC
                    indeed, the autoconfiguration of the pad lacks a few cases, you're one of them. I planned to correct that for 4.1 (no ETA :p) unless i'm allowed to solve it for a hypothetic beta5. I'm soon on holidays, not sure i'll have time I added your error to https://github.com/recalbox/recalbox-os/issues/964 meanwhile, if you DO wish to enjoy moonlight, gotta do it by command line 😕
                    • Anonpebbles
                      Brilliant thanks for your help. Enjoy your holiday!
