    Pc engine iso
    engine iso
    3395
    • metzger130
      metzger130 last edited by
      Can we please make .iso files loadable for PC Engine CD?  Almost all my PCE cd games are .iso files so they will not work in recalbox.
        are they at least shown in ES ?
        • metzger130
          Yes, it shows up under the emulator, but when I try and play, the screen goes blank and then goes back to emulation station.  If I have a .bin file instead of a .iso, it works.  It shows up due to having the .cue file in there also.
            do you have the bios file ?
            • metzger130
              Yes I have the bios file.  Beta 3 on my pi ran .bin files just fine, but .iso files it refused, even after renaming them in the .cue file to all lowercase since it became case sensitive.  Now in beta 4, I have been able to get 1 game running and it was a .cue and bin to begin with.  All my .cue iso's that I converted that ran on my pi beta 3, no longer run on my pi 3 beta 4.  Not sure why this is happening.  The bios is in and it is bold in the bios section of the recalbox.
              • metzger130
                I was able to get most pce cd's to work by checking the .cue file and making sure the letters were lowercase that were supposed to be and .iso is lowercase.  I cannot figure out how to get sapphire to work though (Ginga Fukei Densetsu Sapphire)  Sapphire requires the arcade card on a real pc engine cd unit.  I was able to play it on my pi B with beta 3, but when I bought my new pi 3 and put on beta 4 it will not work.  I get the cd boot up screen and then I hit the run button.  Very quickly the loading screen shows up but then goes away and kicks me out to emulation station again.  did something change in beta 4 for the pce engine that this is not working for me now?
