    How to install Waveshare gamepi20 with Rpi zero w 2
    GamePad/GPIO/USB encoder
    waveshare gamepi20 zero
    • hobbystudent
      hobbystudent last edited by
      Hi all,
      thanks for this great software.
      Does anyone know how to install the waveshare gamepi 20 within recalbox ?
      I am using a raspberry pi zero 2 w and Recalbox 9.1-Pulstar - Raspberry Pi Zero 2.
      The installation guide from https://www.waveshare.com/wiki/GamePi20#Method_2:_Install_driver
      does not work. I get nothing on the display.
      The controller looks like is working but some buttons arewrongly.
      Thanks for any hint.
      Lysy 1 Reply Last reply Reply Quote 0
      • Lysy
        Lysy @hobbystudent last edited by Lysy
        @hobbystudent
        Tried to make it work with RetroPie and Recalbox as well. No luck with manually adding drivers. Got it working with preconfigured RetroPie 4.8 but... I needed to recompile LCD drivers as well:
        https://retropie.org.uk/forum/topic/35177/gamepi20-lcd-once-again-retropie-4-8-and-pi-zero-2-w
        Had the buttons problem also. When I pressed D-PAD the menu was skipping three positions.
        I'd prefer to make it work with 9.1 Recalbox, but things are as they are. There's no proper support from Waveshare.
