    [Question] Create folders for multiple PSX CD games
    Emulator Arcade/PC/Console
    joystick zippy
    • alberto-soage
      alberto-soage last edited by
      How can we create folders for multiple CD games on PSX like the video at 5:30?? https://www.youtube.com/watch?v=G4YJni-sybU
      • digitaLumberjack
        Hi,just create a folder and put all cd iso inside.
        • nickdj
          nickdj last edited by
          Just for an additional note, you can do this and then manually scrape the folder so you get the game image and details. However, if you do an automatic scrape and you see something like 'Tomb Raider - CD 1' and 'Tomb Raider - CD 2' I recommend skipping. If you don't you'll end up with two files in the folder called 'Tomb Raider'. Not a big issue as you can usually assume the first is CD 1 and the second CD 2 however that's again assuming both files are named exactly the same with exception to the last digit. 🙂
          RPi 2 Not overclocked Edimax EW-7811UN LogiLink BT0007A USB bluetooth V2.1 PS3 Controller RecalBox v3.2.8
          • alberto-soage
            Works perfectly! Thanks a lot!
            • renaud-schweingruber
              renaud-schweingruber last edited by
              By the way, how the emulator handles multiples CD ?
