    [Solved]Automount for cifs shared folders not working?
    shaders cifs network drives shared folders automount
    • javipas
      javipas last edited by
      Hi I'm trying to configure my Recalbox to mount several shared folders at boot. I've edited /etc/fstab but after rebooting the folders are not mounted and I can't access them. I can when I mount them manually, but the fstab file seems to ignore my shared folders. An example line for my fstab: //192.168.1.100/Pelis /mnt/pelis cifs username=user,password=pass,_netdev,iocha**et=utf8,x-systemd.automount,noauto,sec=ntlm 0 0 I've read somewhere than on Raspbian you can configure a "Wait for network" boot option so network drives can be detected (with raspi-config) but that tool is not present on Recalbox and I don't see the way to add that option on Recalbox config files. Could someone help me with this? Regards!
        Hello
        do not forget to replace user and password with your own Check this page : https://github.com/recalbox/recalbox-os/wiki/Load-your-roms-from-a-network-shared-folder-(EN)
        • javipas
          Yep, I knew that, I didn't want to put there my real username and password. The link you gave did work. Three differences from what I was doing: 1. The mount line on /etc/fstab uses "user", not "username" 2. I had to add the 'mount -a' option to nano /etc/init.d/S31emulationstation 3. I had to do a 'mv /etc/init.d/S31emulationstation /etc/init.d/S92emulationstation' in order to set that file as the one to boot from and mount everything. Solved! Nice 😉 Thanks!
