    RetroPie saves to Recalbox
    retropie saves
    4657
    • josh-burger
      josh-burger last edited by
      Hello! I'm just getting started with recalbox, since I heard it's better than RetroPie, but I have some games saves (sram and memory card) from RetroPie. Does anyone have an idea of how to transfer these over? Or even know where the .savestate/memory card saves are located on either system? Thanks!
        hello try to /recalbox/share/saves/snes
        • josh-burger
          Thanks for the reply, but I actually copied my entire ROMs folder from RetroPie onto my Recalbox, and at least the memorycard saves weren't detected by the game (Driver 2). Honestly I forgot to check Sega/SNES...
            Is it psx save ? what extension mcr ? if yes : https://github.com/recalbox/recalbox-os/wiki/How-to-use-save-mcr-(from-ePsxe)-with-retroarch-PSX-(EN)
            • josh-burger
              It's the same file format from RetroPie, which also uses Emulation Station/RetroArch. I just don't know where the memory card saves are, therefore I don't know the file format. No errors, just isn't detected by PlayStation games.
                Can you to upload your save file and give me your link in private message and the name of your game SCUSxxx
                • josh-burger
                  All I need is the location of the file first. I don't even know if there's a problem yet...
                  100.8k
