    Retro Achievements popups?
    retro achieveme
    5430
    • javier-arias
      javier-arias last edited by
      It would be a very nice feature to show a popup every time we earn an achievement when we have Retro Achievements enabled.
        No, it is not good idea, popup open when you play .... a message appears on the screen when a retroachievement is won. if you see list Quick Menu > Achievements list
        • javier-arias
          I didn't see any message when I've tested the functionality, is it enabled by default?
            to activate retroachivement, you need an accound in retroachievement website. Go to Emulationsation Menu (start button), > games options > retroachievements > ON and put username and PASSWORD. https://github.com/recalbox/recalbox-os/wiki/Configuration-Retroachievements-(FR) Your game must be compatible with retroachievements and you must use the good emulator. Compatibility game Liste : http://retroachievements.org/gameList.php and yes, message appears in game when you win a trophy, it's enable by default
            • esmith13
              esmith13 last edited by
              I can confirm this. It shows as yellow text across the bottom - exactly the same as when retroarch identifies your controller when you first launch a game. It usually pops up within 5 seconds of doing whatever is needed to earn the achievement. If you retro achievement configuration/login/password are correct you will know it is active whenever you launch an emulator that does support achievements with a game that does NOT support achievements. You will see the yellow text appear at the bottom about your controller and then the message "This game doesn't support achievements".     Eric
              My Raspberry Pi's:
              Pi A, Pi B, (2) Pi B+, (2) Pi 3
              Currently looking for a reason to buy a Pi Zero or two ;-)
              • javier-arias
                Thanks 🙂
