    Can't map C touch on N64 controller
    GamePad/GPIO/USB encoder
    cant map touch
    • Draeke34
      Draeke34 last edited by Draeke34
      [Hi guys,
      I'm new in the retroworld but I recently installed Recalbox (9.1 Pulstar) on a USB KEY (3.1 128go Sandisk) to play on my old computer. The system works correctly but I can't map every touch of my controller. I bought on Amazon the Miadore N64 controller (USB connection) and it is detected as [SWITCH CO., LTD. Controller (Dinput)]. I tried to map it in Recalbox (so each button works fine) but the mapping doesn't ask me for C button ... (So I'm blocked in some games like Banjo).
      I tried to map a Xbox / PS3 controller but the problem is still here, Recalbox doesn't ask me for C touch...
      I searched a bit on net to find a solution and I saw some guys modified directly these followings files :
      Share/System/Configs/mupen64/InputAutoCfg.ini
      Share/System/Configs/mupen64/mupen64plus.CFG
      So I dit it with NotePad++ to map these C touch.
      I save these files and relaunch the Recalbox but It's doesn't works ...
      The mapping is still the old (this one did on recalbox)...
      https://image.noelshack.com/fichiers/2023/43/6/1698484529-capture2.jpg
      https://image.noelshack.com/fichiers/2023/43/6/1698484529-capture1.jpg
      Did someone already had the same issue and found a solution ?
      Thank you for your help and sorry
      Have a good day !]
      100.7k
