    Recalbox 1.9 gba emulador Emulator
    Recalbox general
    recalbox 1.9 emulador
    • Math09
      Math09 last edited by
      Hello, how are you, I have the following problem. All gba games work slow for me, they are only from that emulator, all the others work fine for me.
      I have recalbox 1.9 with a Raspberry Pi Zero W
      SPECIFICATIONS
      -CPU: Broadcom BCM2835 ARMv6 1GHz
      -GPU: Broadcom VideoCore IV 250 MHz
      -RAM memory: 512MB
      -External Storage: MicroSD (not included)
      -USB: 1x Micro USB (OTG) for data and 1x Micro USB for power
      -CSI connector for cameras*
      -Connectivity: WiFi b/g/n, BT 4.1BLE
      -Power: 5V via MicroUSB (power supply not included)
      -Chipset: BCM43438 (WiFi/BT)
      -Size: 65mm x 30mm x 5mm. It is installed on a Retroflag GPI CASE
      What could it be? If anyone can help me I would greatly appreciate it!
      • Magaki
        Magaki last edited by
        Hello,
        PI Zero W = same power as a Raspberry PI 1.
        Not enough power for GBA games, they will be slow, it's normal.
        Math09 2 Replies Last reply Reply Quote 0
        • Math09
          Math09 @Magaki last edited by
          @Magaki I see, I thought it was powerful enough. Thank you!
          • Math09
            @Magaki Is there a way to put a lighter gba emulator so that it can run well? Thank you
            • Magaki
              Impossible to add/update cores by users ; only from Recalbox updates.
              If you can possess a Raspberry PI02W, it's like a PI3, the GBA will be better.
