    Hide / Delete Systems or Emulators - Solution
    hide systems recalbox 9.1 hide delete
    3214
    • Kiliano Lopes
      Kiliano Lopes last edited by
      Hi Guys. English is not my first language, btw, sorry for some erros.
      I have a problem to hide / delete emulators of recalbox. The solution is strange and complicated.
      codeofsystem.ignore=1 in recalbox.conf
      I developed an application in which you can just uncheck the emulators you want to hide, and the code is automatically generated to put in recalbox.conf
      screenshot of website
      https://365indies.com/recalbox-hide-systems/
      • RustyMG
        RustyMG last edited by
        Why not simply select the "hide empty systems" in the settings with just a few button presses?
        It will then not show any system that does not have any ROMs / game files present.
        Sinclair ZX Spectrum 48k "dead flesh" keyboard, Commodore 64, Amiga A500, Amiga A1200, CD32, PC Engine, PS1, PS2, PSP, Nintendo DS, Dreamcast, Wii, XBox 360, Xbox One-X, Pi2, Pi3, Pi4 owner, ARRM contributor ( http://jujuvincebros.fr/wiki/arrm/doku.php ).
        Kiliano Lopes 1 Reply Last reply Reply Quote 0
        • Kiliano Lopes
          Kiliano Lopes @RustyMG last edited by
          @RustyMG Some systems have default game, impossible to delete or hide.
          RustyMG 1 Reply Last reply Reply Quote 0
          • RustyMG
            RustyMG @Kiliano Lopes last edited by
            @Kiliano-Lopes yes, so you just select the "hide pre installed games" option.
            Kiliano Lopes 1 Reply Last reply Reply Quote -1
            • Kiliano Lopes
              @RustyMG IF you hide all pre installed.
              Look... e create a solution for a problem. If you don't like it, don't use it. It's something useful, I made the solution. That simple.
              Juicebag85 1 Reply Last reply Reply Quote 0
              • Juicebag85
                Juicebag85 @Kiliano Lopes last edited by
                @Kiliano-Lopes Thank you so much for your solution. It worked wonderful. 🙂
