    How do I exit out of all games, especially MAME arcade games?
    especially mame arcade
    12
    • ScottCE9
      ScottCE9 last edited by
      I have copies of game ROMS under roms in SHARE partition. Example: I am finished playing Galga on MAME. How do I exit back to the main Recalbox menu?
      poppadum Kiliano Lopes 2 Replies Last reply Reply Quote 0
      • poppadum
        poppadum @ScottCE9 last edited by
        @ScottCE9 Hotkey + Start exits a game
        Or if you have a keyboard attached, Esc
        • Kiliano Lopes
          Kiliano Lopes @ScottCE9 last edited by
          @ScottCE9 hotkey + start.
          The default Button of "hotkey" is select Button. Maybe hotkey (select) + start return to menu.
          If dont work, reconfigure the gamepad and confirm select as a hotkey Button
          • aleciamiles
            aleciamiles last edited by
            Certainly! If you're using Recalbox to play MAME arcade games, here's how you can exit out of games:
            Press the designated hotkey combination on your gamepad. By default, this is typically "Select" + "Start" buttons.
            This should bring up the menu, allowing you to navigate and exit the game.
            Remember, the exact process might vary depending on your specific Recalbox setup and configuration. If you've customized your controls or settings, the hotkey combination might be different.
