    EmulationStation Doesn't Start
    Your recalbox
    doesnt start
    • Profazia
      Profazia last edited by
      When I Start My Raspberry Pi 4 Everything Boots Up Correctly But The Screen Gets Stuck On The Splash Screen of Recalbox Where Pacman Ghosts Are At The Bottom, I Access It Through It's Ip And Open /help Where I Can See the EmulationStation Has Not Been Started I Need To Start It Manually From There Then It Opens Up EmulationStation. If I Run A Game And Exit From There The Same Issue Occurs Stuck On The Same Screen. Can Anyone Tell Me What Is Happening ?
      mantismoranis 1 Reply Last reply Reply Quote 1
      • mantismoranis
        mantismoranis @Profazia last edited by
        @Profazia I have the same issue. This is really frustrating.
        • Damião
          Damião last edited by
          Hi guys,
          Because you face the same issue, I think it will be easier to support you using the same thread, let's continue on this thread? ⤵️
          https://forum.recalbox.com/topic/30389/stuck-on-splash-screen
          Damião
          Recalbox 9.1 + NUC7I7BNH + SSD 2To
          2 Xbox Series Controllers + Wireless adapter
