    How to stop tmp directory being cleared on reboot
    amiberry
    • UncleChuckle
      UncleChuckle last edited by
      Hi. I'm fighting with Amiberry and learned the hard way that it doesn't keep saved configurations. I've tried multiple solutions to get Amiberry to do what I want. My last remaining hope is to STOP the tmp directory being emptied on reboot as that's where it inexplicably saves the configuration.
      I've trawled solutions online and found nothing that actually works. I just want to stop the tmp directory being emptied.
      poppadum 1 Reply Last reply Reply Quote 0
      • poppadum
        poppadum @UncleChuckle last edited by poppadum
        @UncleChuckle /tmp on Recalbox uses a ramdisk so its contents get lost when the power is turned off.
        I think the best approach would be to write simple scripts to save/restore the file(s) you want to keep to/from a location that is permanent e.g. /recalbox/share/. Use the Recalbox event system to trigger that script.
        Example:
        Create /recalbox/share/userscripts/amiberry[reboot,shutdown](sync).sh:
        #!/bin/sh
        cp /tmp/CONFIG_FILE_TO_KEEP /recalbox/share/CONFIG_FILE_TO_KEEP
        And /recalbox/share/userscripts/amiberry[start].sh:
        #!/bin/sh
        cp /recalbox/share/CONFIG_FILE_TO_KEEP /tmp/CONFIG_FILE_TO_KEEP
