    Recalbox Dual not working with Recalbox 9
    recalbox dual
    • mkim78
      mkim78 last edited by
      Downloaded and installed Recalbox 9 on 64GB SD card and put it in my Pi 4 with Recalbox Dual. When I booted it there was no signal received at all and the TV screen just stayed blue with ‘No Signal’ message. I know the Pi 4 and Hat works fine because I can still run Recalbox 8.1.1 just fine on my CRT tv with same hardware. What’s going on? I thought Recalbox Dual was self configuring and would work automatically with latest Recalbox version. Am I not doing something obvious? Many thanks in advance for any advice
      mkim78 1 Reply Last reply Reply Quote 0
      • mkim78
        By the way, I have the Recalbox Dual with the green PCB board that was purchased in late 2022
        • mkim78
          mkim78 @mkim78 last edited by
          Ok so basically Recalbox Dual only works with OS 9 Pulstar if you do an update from a working version of Recalbox 8. If you do a fresh install of currently available Recalbox 9 on a SD card it won’t work with Recalbox Dual. I would advise against purchasing Recalbox Dual until they have a version of Recalbox 9 that works with the hardware
