    Unsolved tweakvec on new recalbox 9.0 pulstar problem
    rbpi4 composite tweakvec phyton ntsc
    • IGA
      IGA last edited by IGA
      Hello everyone!
      I've still use RPi4 with crt tv connected via composite cable.
      In previous versions of recalbox i've used TweakVec to fix ntsc' colors and get PAL60 mode.
      I've used WinSCP to put tweakvec.py file to sd card's share partition, then used terminal and just write command:
      tweakvec.py --preset PAL60
      After that i've got true colors and 60fps/
      It's worked on Recalbox 7, 7.1, 7.1.1, 8.0, 8.1-electron.
      But now, on 9.0-pulstar it's doesn't work!
      After entering command on the terminal i've get message:
      */recalbox/share$ tweakvec.py --preset PAL60
      -bash: line 13: tweakvec.py: command not found
      /recalbox/share$ python3 tweakvec.py --preset PAL60
      File "/recalbox/share/tweakvec.py", line 73
      <title>tweakvec/tweakvec.py at main В· kFYatek/tweakvec В· GitHub</title>
      SyntaxError: invalid character 'В·' (U+00B7)
      Why?
      And what i need to do make it's work correct again?
      IGA 1 Reply Last reply Reply Quote 0
      • IGA
        IGA @IGA last edited by
        update:
        sorry, i've used wrong file... ( and i can't edit first post of topic)
        and full command was:
        But now, it's said:
        • DeprecationWarning: The distutils package is deprecated and slated for removal in Python 3.12. Use setuptools or check PEP 632 for potential alternatives
          import distutils.util
        and I'm not understanding....
        • Topic has been marked as a question  IGA IGA
