    Some C64 ROMs do start, some don´t, why?
    Emulator Arcade/PC/Console
    c64 roms start don´t
    • bubbler
      bubbler last edited by
      I have several ROMs that don´t start at all. I just get the blue screen and READY, but nothing else happens.
      These are T64 ROMs.
      But other T64 ROMs work, they start with Load"*",8,1
      Why do some start and others don´t?
        Scavy Global moderator @bubbler last edited by
        @bubbler concerning C64, downloading may also be... very very very long ^^
        bubbler 1 Reply Last reply Reply Quote 0
        • bubbler
          bubbler @Scavy last edited by
          @Scavy The thing is, loading does not even start. Nothing happens, only "READY" and the blinking cursor
          • Araukaria
            Araukaria last edited by
            Same here.
            My System is a Raspy 3 running Recalbox 9. Since the update from 8 to 9 none of the C64 Roms ist running properly.
            Most of them don´t start anymore. The few ones starting, have a cracked sound and are running slowed down.
            I changed the Emulator in the configuration menu several times, the problems stay the same.
            All other systems are running properly.
            artman5 1 Reply Last reply Reply Quote 0
            • artman5
              artman5 @Araukaria last edited by
              @Araukaria
              Had same issue with c64 games. Seems to work if all bioses are pressent using libretro vice_x64 emulator running on rp3b+.
