    System menu on FBA
    Emulator Arcade/PC/Console
    fba
    5746
    • adrianlobster
      adrianlobster last edited by
      <span lang="en">Greetings to all forum! I'm new here and I'm not sure if there is a topic on this subject . If not , someone would know if there is a way to access the system setup menu in Final Burn and Burn Final Libretto ? One in which we define things like difficulty of the game ? I thank you and apologize for my terrible English!</span>
        Hello read this page : https://github.com/recalbox/recalbox-os/wiki/Use-Neogeo-Unibios-(EN)
        • adrianlobster
          <span lang="en">Oh , yes , Acris , I had even given a look at this page, but my question was about how to access this menu in Capcom games of CPS 1 , 2 and 3 ! The page you gave me speaks only in the case of Neo Geo games, right?</span>
            To access retroarch menu (hotkey+b) may be dipswitch menu try L3 or R3 may be for libretro fba or start hold few seconds ?
            • adrianlobster
              <span style="color: #212121; font-family: arial, sans-serif; white-space: pre-wrap;">So I can 'll test your suggestions and give you a return , Acris ! From already thank you very much for your attention! :D</span>
                Hello hotkey+b core quick menu > core options > Visionner l'image
                • adrianlobster
                  <span lang="en">Sorry Acris for taking so long to make a return ! Evidence season is a serious problem ! But the road was the same you indicated ! Let laziness aside and I move in the Core configuration ! I activated the " settings for core" and set the control assigning a button to the " diagnostic" which was pre configured for the R3 button. and interestingly it did not work. Then assign the L2 and it worked perfectly! For me the choice was lacking to leave the emulation perfect arcade in Recalbox ! Many, many thanks for your attention my friend! I'm new here and a good novice user , but I hope to give a nice return over time! Big hug! And I apologize for my terrible English! XD</span>
