    Rgb on pc, x86 for crt, is it posible?
    rgb x86 crt posible
    • abispac
      abispac last edited by
      Hey guys, so i have recalbox runing on a pi4 with a vga666 and rgb on a crt monitor, so far so great, so it got me wonder, is it posible to achieve the same on a pc with an amd card? Ive looked on google and here, but couldnt find any information. Thanks for your time.
      iToNkY 1 Reply Last reply Reply Quote 0
      • iToNkY
        iToNkY @abispac last edited by
        @abispac Unfortunately we can't, the alternative is BATOCERA, I hope one day Recalbox achieves CRT output on x86
        • Asalam
          Asalam last edited by
          Hey there,
          It's awesome to hear that you have Recalbox running smoothly on a Raspberry Pi 4 with a VGA666 and RGB setup on a CRT monitor. It's a unique and nostalgic gaming experience! Now, regarding your question about achieving the same setup on a PC with an AMD card, here's some information.
          Recalbox is primarily designed for single-board computers like the Raspberry Pi, and it may not have official support for running directly on a PC with an AMD card. However, that doesn't necessarily mean it's impossible to achieve a similar setup.
          To explore the possibilities, you could consider using a PC emulator or virtual machine with an operating system that supports Recalbox. For instance, you could install a lightweight Linux distribution, such as RetroArch, Lakka, or Batocera, on your PC and configure it to emulate the same gaming experience as Recalbox. These distributions often have better compatibility with PC hardware, including AMD graphics cards.
          Another option is to look into specialized front-end software like EmulationStation or RetroPie, which can be installed on a PC running Windows or Linux. These front-ends allow you to organize and launch your emulated games while providing a user-friendly interface. While they may not offer the same plug-and-play experience as Recalbox on a Raspberry Pi, they can still provide a similar gaming environment.
          I recommend exploring forums and communities dedicated to retro gaming enthusiasts, as they might have more specific knowledge and experience with running Recalbox-like setups on PCs with AMD cards. Sharing your question there could yield valuable insights and possible solutions.
          I hope this information helps you in your quest to recreate the Recalbox experience on a PC with an AMD card. Good luck, and enjoy your retro gaming adventures!
