    No sound in menu recalbox 9.0 rbp3b
    sound recalbox 9.0 rbp3b
    • firebomber13
      firebomber13 last edited by
      I am using version 9.0 recalbox on a rasb pi 3b
      my problem is that when starting recalbox the audio is not heard in the menu, however it sounds perfectly in the intro when it is turned on and when running games these are also heard, the problem is only in the menu, it is not that serious but if it is uncomfortable
      t7sturgis firebomber13 2 Replies Last reply Reply Quote 1
      • t7sturgis
        t7sturgis @firebomber13 last edited by
        @firebomber13 mine has done also. I went to sound settings changed to audio output port then back to hdmi output this fixed my problem.
        firebomber13 1 Reply Last reply Reply Quote 0
        • firebomber13
          firebomber13 @t7sturgis last edited by
          @t7sturgis Hello friend, I have done what you say. It works but when I restart the rpi3 or exit a game to the main menu the problem returns. Thanks for write.
          • firebomber13
            firebomber13 @firebomber13 last edited by
            @firebomber13 said in No sound in menu recalbox 9.0 rbp3b:
            hello everyone, I found a solution to have no sound or slow music in the Recalbox menu.
            what I did was once I had the micro sd with recalbox, put it in the raspberry so that it can make the corresponding configurations. After it finishes configuring, turn off and connect the micro sd card to the pc, look in the RECALBOX partition for the recalbox-user-config.txt file, once opened, leave the following lines as you are:
            #uncomment to force a specific HDMI mode (this will force VGA)
            hdmi_group=1
            hdmi_mode=4
            then save the changes and with that it should solve the problem.
