    Where is es_systems.cfg?
    where essystems.cfg
    11493
    • george-brooks
      george-brooks last edited by
      i would like to add the .pbp file extensions to the psx emu, but i cant find the es_systems.cfg file anywhere to add them. its not in ~/.emulationstation. where is it?
        Hello in recalbox 4.xxx pbp extensions is already added : https://github.com/recalbox/recalbox-buildroot/blob/rb-4.0.X/board/recalbox/fsoverlay/recalbox/share_init/system/.emulationstation/es_systems.cfg#L264
        • george-brooks
          Thank you again for your help!
          • docbenton
            docbenton last edited by docbenton
            i am looking also file es_sytems.cfg as described here.. http://emulationstation.org/gettingstarted.html#config
            my aim is to add in command to lauch retroarch, a redirection of standard output to /recalbox/share/system/logs/retroarch.log
            i think it would resolve a mame game freeze issue that i have described in https://github.com/recalbox/recalbox-os/issues/781 (and persist the workaround, tail /proc/<retroarch_pid>/fd/1
            (i was not able to find the config around retroarch mame command line in recalbox config... did not yet figured it out from source code.. only found sample here and SYSTEMS.md)
            any help to resolve this issue would be appreciated !
            regards
            • supernature2k
              supernature2k last edited by
              Hi, es_systems should be in share_init/system/.EmulationStation
              You can copy it to share/system/.EmulationStation for easier access.
              • docbenton
                ok you mean /recalbox/share_init/system/.emulationStation/es_systems.cfg
                I made a copy in /recalbox/share/system/.emulationstation
                but once restarted, i do not get in emulstationmenu/.. advanced options/ mame the choice with two values defined here for instance :
                <emulator name="libretro">
                <cores>
                <core>imame4all</core>
                <core>mame078</core>
                </cores>
                </emulator>
                so i am not sure its actually read...
                btw i've found where the command is composed and launched , redirection of standard output could be put here..https://github.com/recalbox/recalbox-configgen/blob/4.0.0/configgen/emulatorlauncher.py#L151
