    PI Boy DMG Green LED Brightness
    boy dmg green led brightness
    • cruz1383
      cruz1383 last edited by
      Hello I have been using Recalbox on the Pi boy DMG and it has been great. I wanted to know if there was a way to lower the top green led as it is too bright. I know when I used retropie and the DMG OSD script I was able to change its value and get it to lower its brightness or make it brighter. Recalbox doesn't have a script to do that does it ? if it does can anyone point me in that direction it would be greatly appreciated.. I have tried using it at night and that LED is unbearably too bright at night.
      sebafx poppadum 2 Replies Last reply Reply Quote 1
      • sebafx
        sebafx @cruz1383 last edited by
        @cruz1383 Hi, do you managed to fix this? Thanks in advance!!!
        • poppadum
          poppadum @cruz1383 last edited by
          @cruz1383 Is the green LED the Pi's built-in activity LED? If so, it can be controlled from software.
          To turn it off you could try putting
          dtparam=act_led_trigger=none
          in /boot/recalbox-user-config.txt and rebooting your Recalbox.
          See the Raspberry Pi overlay docs for more details.
