    Previous versions of recalbox.
    Emulator Arcade/PC/Console
    previous versions recalbox
    • Mariseus
      Mariseus last edited by
      Greetings. I apologize in advance if I am writing this topic in the wrong section.
      There was a problem: I have a rasberry pi 3 b+. Not so long ago I installed recalbox 4th (if I'm not mistaken) version. Everything worked stably. Later, the OS offered me to upgrade. Updated. Result: black screen and red and green LEDs do not work. Just in case, I installed other OSes to understand what was going on. Everything works.
      Well, in general, the question is: where can I get an image of an earlier version of recalbox?
      Thank you in advance.
        Scavy Global moderator @Mariseus last edited by
        @Mariseus hi
        you can't update from version 4 to version 8, it requires a fresh install.
        I suggest you download the latest version and configure it 🙂
        101.4k
