    Ipega 9021 dont work
    GamePad/GPIO/USB encoder
    ipega 9021 dont
    5596
    • gerickt
      gerickt last edited by
      Hello everyone, I am new to recalbox ... retropi used before, but decided to migrate by good reviews I've seen on all sides ...I can not run my gamepad bluetooth ipega 9021 ... I can match up, but nothing happens ... but the system does not allow me to set it up ... I saw the forum and saw some changes command line with the 9025 model, try but it does not work as I am using the latest version 4.0.0 I think I hope someone can give me a hand ... Thank you pd: sorry for my English
      • rammstein
        rammstein last edited by
        Hello, I retried the config for my ipega 9025 with the recalbox 4.0.0 beta 3, and it still works. Just need to modify the beginning of bluetoothcontrollers.sh as :
        bluetoothd -u
        sleep 5
        killall bluetoothd
        • gerickt
          thanks! works now... but, don't work inside the game... in the menu works greats!, any ideas? regards
          • rammstein
            In recalbox.conf, try global.inputdriver=sdl2
            • gerickt
              works like a charm !!!, thank u additionally I had to add this line ... for my 9021 model (bolded) echo 'SUBSYSTEM == "input" ATTRS {name} == "Gamepad", MODE = "0666", ENV {ID_INPUT_JOYSTICK} = "1"'> /etc/udev/rules.d/99-gamepad. rules
                Hello @Gerickt I need your es_input.cfg to add your gamepad out of box in recalbox. in ssh : /recalbox/scripts/recalbox-support.sh Can you upload the archive request in this page : https://github.com/recalbox/recalbox-os/wiki/Recalbox-support--(FR)
                101.4k
